virtual templates
mostafaammar
we have a 3845 cisco router , we are using 2 virtual templates (we are using ppp over frame relay)interfaces to bundle our internet and vpn connection .
the internet virtual template is bundling 8 serial interfaces , and it is working fine .
the vpn virtual template is bundling 4 serial interfaces (we are using ppp over frame relay ) , the output traffic from the router is load balanced but there is a problem in load balancing the input traffic to the router , the input traffic is on one serial interface and no traffic on the other 3 serial interfaces , when trying to use another router for the vpn virtual template it works fine and the input traffic is load balanced , is there a problem to have multiple virtual templates on the same router
10 Replies 10
Amit Singh2000
the outbound load balancing is easy to achieve . CEf automatically takes care of that. but inbound is pretty tough. coz when u send a request its outbound . load balanced. but response can be very big file. example downloads.
if both routers r in ur control try enabling ip cef per packet.
hope that helps u.
regards
A better way to do this would be to create multilink interfaces and make these virtual templates part of the multilink.
We have this setup in our network and the load is balanced more or less equally
regards
Narayan
Dear royalblues ,
thx for ur fast reply ,may you verify that the following configuration are correct ( correct me if i am wrong ), i am configuring 2 multilink interfaces one for internet and the other for the vpn .
should i configure frame-relay traffic shapping under the serial interfaces ?
should i configure ip cef per packet on my router and the service provider router ?
configuration :
! the internet virtual template
interface virtual-template 1
description internet virtual template
no ip address
ppp multilink group 1
ppp multilink fragment delay 20
ppp multilink interleave
end
! internet multilink interface
interface multilink 1
description internet multilink group
ip address ip-address mask [secondary]
!vpn virtual template
interface virtual-template 2
description vpn virtual template
no ip address
ppp multilink group 2
!vpn multilink interface
interface multilink 2
description vpn multilink group
!internet serial interface
inter serial 0/1/0
no ip address
encapsulation frame-relay
frame-relay lmi-type q933a
interface serial 0/1/0.1
ip address
frame-relay interface-dlci 16 ppp Virtual-Template1
!vpn serial interface
inter serial 0/2/0
description vpn
no ip address
ip address
frame-relay interface-dlci 16 ppp Virtual-Template2
Using per packet will give you equal load sharing of the links but if the latencies across these links differ then packets can arrive out of sequence at the other end
Here's a sample config i have
interface Serial0/0/0:0
bandwidth 1536
no ip address
encapsulation frame-relay IETF
keepalive 1
frame-relay lmi-type ansi
interface Serial0/0/0:0.1 point-to-point frame-relay interface-dlci 755 ppp Virtual-Template1
interface Serial0/0/1:0
bandwidth 1536
no ip address
keepalive 1
interface Serial0/0/1:0.1 point-to-point
bandwidth 1536
keepalive 1
no cdp enable
frame-relay interface-dlci 312 ppp Virtual-Template2
interface Serial0/1/0:0 bandwidth 1536
no ip address
load-interval 30
keepalive 1
interface Serial0/1/0:0.1 point-to-point keepalive 1
no cdp enable
frame-relay interface-dlci 555 ppp Virtual-Template3
interface Virtual-Template1
bandwidth 1536
no ip address
keepalive 1
ppp multilink
interface Virtual-Template2
bandwidth 1536
no ip address
keepalive 1
ppp multilink
interface Virtual-Template3
bandwidth 1536
no ip address
keepalive 1
ppp multilink
interface Multilink1
ip address 172.16.2.13 255.255.255.252 load-interval 30
keepalive 1
no cdp enable
ppp multilink
HTH, rate if it does
Narayan
my dear friends,
ppp multilink will not help the inbound load balancing.since ur u have configured ppp multilink means that ISP end is also configured for the same. so if possible get ur isp to configure the ip cef per packet.
outbound will be load balanced from ur end inbound will be load balanced by ISP..
hope this help.
regards
Dear All ,
when using virtual templates , can i bundle more than one serial interface to the same virtual template or every serial interface should be bundled to one virtual template interface ?
hi,
if you wanna bundle serial links use ppp multilink and interface multilink. rather than using virtual template.
regards
Mostafa,
You can associate serial links to the same virtual interface. It is possible to do that. But it is always recommended to have each of serial links associated with a different virtual template.
Amit, you cannot use normal PPP multilink when you have a frame-relay cloud. you have to either configure MFR or MLPPoFR which will introduce virtual templeates
Narayan
Hi Amit,
Please allow me to interrupt and ask a question here, what is the reason behind preferring interface multilink over using virtual-template with ppp multilink configuration ?
Thanks in advance,
Mohammed Mahmoud.
Hi Mohamed ,
the interface virtual template is always down down (however it is working )and it creates virtual access interfaces for every serial interface bundled and 2 more virtual access interfaces than the serial interfaces .these 2 virtual access interfaces one for management of the bundle and the other one is for aggregating the links . the multilink interface aggregates the traffic itself so when u issue the command show interface multilink 1 u see the aggregated bandwidth of the bundle . and it is up u so u can track the interface and use a backup interface .
best regards,
Mostafa Ammar
