12-19-2013 11:48 PM - edited 03-07-2019 05:11 PM
Hello at all,
I have configured a Cisco Nexus 5000 as L 3 Core switch and have now the problem when i try to access an access swicht in VLAN 1 from another Vlan or from outside i get no answer. When I connect a PC on a Interface of the access switch everything is working. Did anybody have a idea?
Matthias
Solved! Go to Solution.
12-20-2013 12:50 AM
did you configure the nexus as default gateway on the access switch ?
Alain
12-20-2013 12:50 AM
Alain
12-20-2013 01:33 AM
Hi Alain,
thanks for the answer looks like I`am blind today :-)
