VLAN 3560
HI,
please tell me (or give me a tutorial about) how to create a VLAN and configure a couple of ports on the Cisco 3560 V2 PoE-48.
Adrian.
1 ACCEPTED SOLUTION
VLAN 3560
Hello Adrian,
How to create the vlan
vlan 10
description test "this is optional"
How to add ports to the vlan
interface fast 0/2
switchport
switchport mode access
switchport access vlan 10
What if you want to configure the Switch as the default gateway for that VLAN (SVI)
Interface vlan 10
ip address 10.10.10.1 255.255.255.0
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
VLAN 3560
Hello Adrian,
vlan 10
interface fast 0/2
switchport
Interface vlan 10
Jcarvaja
Julio Carvajal
VLAN 3560
I want to connect a UC 540 and several IP phones on that switch;  from switch, I want to route traffic to an IP adress (a radiostation with networking capabillities) and send it Over The Air to another point. I need a router for that or 3560 it's enough for that?
VLAN 3560
So is that radiostation within the same subnet than vlan 10?? If yes you actually do not need to configure L3 capabilities on the Switch as ARP will do the job but if that radiostation is on a different vlan/subnet then the Switch can work as a L3 device and do the job
Jcarvaja
Julio Carvajal
VLAN 3560
Hello again,
and thank you for your response. I have this situation now: in point A, I have UC 560, switch 3560 v2 PoE 48, 2 Cisco Ip phones ; in point B, I have switch 3560 v2 PoE 48, 2 Cisco Ip phones. All equipment is configured and functional; the switches are connected through straight cable, between fa 0/2. Vlan's are configured too; interface fa 0/2 (3560) trunked.
Instead of connecting cable, I'll have a radionetwork. The ends of this radionet are in different subnets, but one are the same with one 3560(the one connected with UC 560). So, I'll need to interpose two 2901. Please tell me the settings for these routers.
Adrian
VLAN 3560
Hello Adrian,
Can you build a diagram and what you want to achieve. I want to be as accurate as possible
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
Julio Carvajal
Re: VLAN 3560
I want to extend my voip Over the air. Please feel free to use any example of ip address, and imagine the radionet acting as a straight cable between ge0/0 routers interfaces, one in 192.168.30.0 and the other one in 192.168.50.0. Ge01 interfaces are for links to switches. There are a voice vlan and data vlan, trunked at fa0/2 interface of switch A. fa 0/1 are conected with uc560. The phones are connected to fa0/10 and 0/11 both side(A,B).I'm sure you understood perfect, and sorry for my english...:)
Thank you,
Adrian.
VLAN 3560
Please help me Mr. Carvajal; I'm in an isolated outpost, and my network must be fully functional until wednesday morning.
Adrian.
Hall of Fame Super Blue
Re: VLAN 3560
Hi all
If possible can we post into the link below as i am trying to get all answers into the same thread and the same question about connnecting via radio link has been posted multiple times -
https://supportforums.cisco.com/thread/2262246?tstart=0
Jon
VLAN 3560
Check out my blog.. i explained it with the screenshots too.
http://network-addicts.blogspot.in/2013/12/vlans-explained-practically.html
Chandu
Regards, Chandu
261
