Webcast-Catalyst9k
Vlan Access-Map (Mac addresses) - not working
I have applied the following config to a Cisco 6509 to restrict to only 2 physical devices in the vlan and nothing else.
I have since dropped a laptop into the vlan and configured an address within the vlan range and I can ping anything inside the network and outside the network.
Extended MAC access list acl1
permit host 0050.6005.4c29 any
permit host 0050.600c.c716 any
Vlan access-map "acl1vmap"  10
match: mac address acl1
action: forward
Vlan access-map "acl1vmap"  20
match: mac address any
action: drop
vlan filter acl1vmap vlan-list 603
Any help would be appreciated
Steve
1 REPLY
I guess switch must have learn all the  MAC address or ARP entry before you apply the MAC ACL and looks like you plugged laptop after that so its not working.
Try to reconfig ACL config while laptop is not unplugged.
Just a thought or try from any other machine which was already in there.
Ajay
585
