VLAN behaviour on Hybrid Swicth ?
I have a Cisco switch "WS-C5505" with MFSC (Router - WS-F5541)
I have a Vlan configured on the Router "MFSC" and a physical interface on the swicth module 3/1. I will like to find out if the router VLAN will go done if the physical interface on the switch module 3/1 goes down ?
Re: VLAN behaviour on Hybrid Swicth ?
Hi Friend,
Yes if there is no active physical port on supervisor for that vlan (access port or trunk port) layer 3 interface for that vlan on RSFC will go down?
You cannot have MSFC on 5500 switch either it will be RSFC or RSM. I believe its a typo error from your side.
Ankur
Yes it is RSM on the 5500........... i have been spending more time on cat6500 hence the typo.
154
