VLAN , Catalyst 3750G, Layer 3
i have 4 different ip networks like:
layer 3 switch:
192.168.0.0/26 GW 192.168.0.1
192.168.0.64/26 GW 192.168.0.65
192.168.0.128/26 GW 192.168.0.129
this one is on a layer 2 switch
192.168.0.0/24 GW 192.168.1.1
all the communication should use vlan 2!
on the layer 2 switch
port 1: access vlan 2
port 2: vlan trunk 2
on the layer 3 switch
port 1: ip address 192.168.0.1
port 2: ip address 192.168.0.65
port 3: ip address 192.168.0.129
port 4: vlan trunk 2
vlan 2: ip address 192.168.1.1
is it possible to say all traffic over port 1,2,3 on layer 3 switch should have the vlan2 attached and can so only communication on the layer 2 switch with all other vlan2 ports?
thanks for help
Hall of Fame Super Silver
Re: VLAN , Catalyst 3750G, Layer 3
Hello Christian,
if ports 1,2,3 are used as L2 ports this is possible with
int fasx/y
switchport
switchport mode access
switchport access vlan 2
if you want to use the ports as routed ports as you write this is not possible and not recommended.
The recommended design rule is:
one to one corrispondence between an IP subnet and a Vlan (a L2 broadcast domain).
in this case you can define 4 L2 objects vlans
conf t
vlan 2
vlan 3
vlan 4
vlan 5
then you create for each a L3 interface
int vlan 2
ip address 192.168.0.1 255.255.255.192
! important
no shut
int vlan 3
ip address 192.168.0.65 255.255.255.192
! important
no shut
and so on
and at the same mode for each then you associate ports 1-3 to vlan 2 as explained above.
Edit:
port 4 in trunk mode has to connect to L2 switch and you are fine
the key is that a multilayer switch can be used also as L2 switch when needed on a per port basis.
Hope to help
Giuseppe
okay thanks for information.
But the config on the layer switch is then like:
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface Vlan2
interface Vlan21
interface Vlan22
ip address 192.168.1.65 255.255.255.192
i tested it:
connect a pc with ip 192.168.1.2 gw 192.168.1.1 and could not reach the router.
but when i say in config:
switchport access vlan 21
i can reach the router
hope you understand my issue
Hello Christian,
interface Vlan22 ip subnet overlaps with vlan2 this config shouldn't be accepted I guess you have just mistyped.
You need to verify that the L2 path in Vlan2 is complete and correct:
check the trunk ports on the L3 switch and L2 switch
use
sh int typex/y switchport
verify that both ports are trunking, using the same encapsulation, and if 802.1Q (dot1q) you need to verify they agree on native vlan (untagged) identity. And both sides of the trunk have to allow vlan2
if you like you can post
sh cdp n
Hope to help
Giuseppe
hi,
maybe the network plan can help understanding my problem. i just want to know if its so possible
that host 1 can communicate with host 2 (different networks) and using both vlan 2.
networkplan:
http://www.smokey-co.com/vlan.jpg
Hello Christian,
the short answer is no
IPv4 hosts cannot talk to each other in different IP subnet without the help of a router/multilayer
to accomodate multiple ip subnets on the same L2 vlan you need something like:
int vlan2
ip address 192.168.0.1 255.255.255.0
ip address 192.168.1.1 255.255.255.0 secondary
this is not recommended in switched environment
each host has to be connected to a port that is associated to the right vlan (if its address is statically configured)
Hope to help
Giuseppe
138
