Webcast-Catalyst9k
vlan config
Hi,, i m configuring a vlan in 3750 switch.. but the vlan is showing down..
1 ACCEPTED SOLUTION
Blue
Re: vlan config
You need to have at least one host in that vlan connected to the switch and in an 'up,up' state. Or a trunk port in the 'up,up' state that carries the vlan.
Victor
1 REPLY
Blue
Re: vlan config
Victor
139
