08-16-2013 02:28 AM - edited 03-07-2019 02:58 PM
I am new the Vlan configuration. Recently I have purchase cisco L3. I want my sonicwall to be the primary L3 routing. We have around 2000 users. Users need to be get ip from sonicwall(DHCP).
My ip plan is as below.
Sonicwall Ip : 10.10.20.1
Cisco 3560 Management Vlan1 ip : 10.10.20.2
Vlan 10 : 10.10.0.1/255.255.252.0
Vlan 20 : 10.20.0.1/255.255.254.0
Vlan 30 : 10.30.0.1/255.255.254.0
vlan 40 : 10.40.0.1/255.255.252.0
Vlan 50 : 10.50.0.1/255.255.255.254.0
Vlan 60 10.60.0.1/255.255.255.0
Vlan 70 ip : 10.70.0.1/255.255.254.0
Vlan 80 : 10.80.0.1/255.255.254.0
All Vlan port will connected to respective building L2 switch( like Vlan 10 Port 1 connected to Academic building cisco L2 switch, Vlan 20 port 2 connected to mechanical building L2 et.,) I have 8 access points. It connected to L2 switches. Access point controller connected to L3 switch. User will be get ip from sonicwall.
How can I configure L3 and L2 switch? Pl guide.
Thanks.
08-16-2013 04:02 AM
You'll need to have routing enabled to route between vlans with the "ip routing" command. (It may be on by default on the 3560X.) You'll need to create L3 svis to attach to the vlans on the switch after you create the vlans:
vlan 10
vlan 20
etc.
int vlan 10
ip address 10.10.0.1 255.255.252.0
no shut
int
switchport mode access
switchport access vlan 10
You can do this for all of the vlans. To get dhcp, let's assume the main dhcp server is on vlan 10. On every other vlan interface you would add "ip helper-address
int vlan 20
ip helper-address 10.10.0.100
Technically, you won't need to do anything with vlans on the sonicwall. You just need to route back to the 3560 for all of your subnets, and you can do that with a static route or ospf/rip if the Sonicwall supports that. I would recommend ospf if you have the option....
HTH,
John
*** Please rate all useful posts ***
08-16-2013 05:27 AM
Thanks your reply John,
As per the Sonicwall guidence i have done the below configuration at L3, now all vlan is working and users get respetive ips, i have connected Access point controler to port no 15. The problem is cant communication between access point controler and access point(except Admin building Access point, which is connected to vlan 30). Kindly guide me.
User Access Verification
Password:
Switch>en
Password:
Switch#sh run
Building configuration...
Current configuration : 4393 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5 $1$rv8J$rIMAenBP8yMbdlr2HbFPM.
no aaa new-model
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet0/1
spanning-tree portfast
interface GigabitEthernet0/2
switchport access vlan 20
interface GigabitEthernet0/3
switchport access vlan 30
interface GigabitEthernet0/4
switchport access vlan 40
interface GigabitEthernet0/5
switchport access vlan 50
interface GigabitEthernet0/6
switchport access vlan 60
interface GigabitEthernet0/7
switchport access vlan 70
interface GigabitEthernet0/8
switchport access vlan 80
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description trunk link to sonicwall
switchport mode trunk
speed 100
duplex full
no cdp enable
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
interface TenGigabitEthernet1/2
interface Vlan1
ip address 10.10.20.2 255.255.255.0
no ip route-cache
no ip mroute-cache
ip default-gateway 10.10.20.1
ip classless
ip http server
ip http secure-server
snmp-server community public RO R0
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
08-16-2013 06:38 AM
i did'not see any vlan in your config
you must create all vlan
interface valn 10
IP address ?
no shut
intterface vlan 20
ip address ?
no shut
interface vlan 30
ip address ?
no shut
also check from
sh ip int brief
all vlan exist are up if its not up that means its down .
Jawad
08-16-2013 06:44 AM
In order to route out of the vlan (port 15 being an access port), you'll need to have an svi attached to the vlan. Create a vlan 30 interface (int vlan 30) and assign the respective address to it. Make sure that you change the devices on that vlan to use the interface vlan 30's ip address as their default gateway.
HTH,
John
08-16-2013 08:45 PM
thanks,
can you provide me full command, so that i can configure the same and resolve this proble,
08-17-2013 04:02 AM
On L3 Switch Configure These vlans as below
interface vlan 1
ip address 10.10.20.1 255.255.255.0
no shut
interface vlan 10
ip address 10.10.0.1 255.255.255.252.0
no shut
interface vlan 20
ip address 10.20.0.1 255.255.254.0
no shut
interface vlan 30
10.30.0.1 255.255.255.254.0
no shut
interface vlan 40
ip address 10.40.0.1 255.255.252.0
no shut
interface vlan 50
ip adress 10.50.0.1 255.255.255.254.0
no shut
interface vlan 60
ip adddress 10.60.0.1 255.255.255.255.0
no shut
interface vlan 70
ip adress 10.70.0.1 255.255.254.0
no shut
interface vlan 80
ip address 10.80.0.1 255.255.255.254.0
no shut
VLAN 1
name Management
Vlan 10
name Academic
Vlan 20
name Mechanical
Vlan 30
name Admin
Vlan 40
name Diploma
Vlan 50
name MBA
Vlan 60
name Workshop
Vlan 70
name E&TC
Vlan 80
name Computer
ip routing
interface fastethernet 0/24
***Description Connected to Academic Building Switch ***
switchprot trunk allowed vlan 1,10,20,30,40,50,60.70,80
interface fasterthernet 0/23
***Description Connected to Mechanical Building Switch ***
interface fasterthernet 0/22
***Description Connected to Access Point Switch ***
interface fasterthernet 0/20
***Description Connect to SonicFW ***
switchprot access vlan 1
L2 Switch Configuration will be same for all l2 switches
interface vlan 1
ip address 10.10.20.5 255.255.255.0 (for management purpose just change ip on other L2 Switches)
no shut
interface vlan 10
no shut
interface vlan 20
no shut
interface vlan 30
no shut
interface vlan 40
no shut
interface vlan 50
no shut
interface vlan 60
no shut
interface vlan 70
no shut
interface vlan 80
no shut
VLAN 1
name Management
Vlan 10
name Academic
Vlan 20
name Mechanical
Vlan 30
name Admin
Vlan 40
name Diploma
Vlan 50
name MBA
Vlan 60
name Workshop
Vlan 70
name E&TC
Vlan 80
name Computer
ip defaul-gateway 10.10.20.2
*** Description will be contted to l3 Switch***
Now Keep IN mind
all respective clients that belong vlan
gateway will be their respective vlan that u have created for each client on l3 Switch
e.g
vlan 10 client
gateway will be L3 Switch vlan IP
10.10.0.1
vlan 20 cleint
gateway will be l3 switch vlan ip
10.20.0.1
etc... like dat
***Do Rate All Helpful Posts***
08-17-2013 04:05 AM
Adding
L2 Switches if u want to assing interface to vlan
just go under that interface
interface fastethernet 0/1
switchport modes access
switchport access vlan x (which ever u want to assign)
Jawad
08-17-2013 04:17 AM
Thanks for your support, i will configure and let you know.
08-18-2013 09:13 PM
thanks for your support, i like to be add the below DHCP on my sonicwall and user will need to be get this scope from sonicwall, can you pl tell how can i configure at L3?
10.10.0.21 - 10.10.3.254
10.20.0.21 - 10.20.1.254
10.30.0.21 - 10.30.1.254
10.40.0.21 - 10.40.3.254
10.50.0.21 - 10.50.1.254
10.60.0.21 - 10.60.0.254
10.70.0.21 - 10.70.1.254
10.80.0.21 - 10.80.1.254
08-17-2013 05:01 AM
08-18-2013 09:42 PM
i have move this forum to Lan & switching.
08-19-2013 11:51 AM
Does anyone have any advice on how to get my VLANs connected to the internet?
08-19-2013 07:52 PM
vinish u have not provided feedback of above configuration which i provided.
for internet to work u will have to add default route in your 3560
ip route 0.0.0.0 0.0.0.0 (next ho gateway Internet Device IP)
****Do Rate All Helpful Posts****
Jawad
08-19-2013 09:21 PM
Hi, Jawad, your configuration is very very helpful for me and my team, thanks for your helpful support. i have done all configuration on L3 & sonicwall, now user able to get respective VLan ip & internet. i need your support always. once again thanks.
