vlan configuration
andyrintoul
More Vlan inquiries.
I have just completed a vlan simulation with 2 x 2950 switches, one in server mode & one in client with a trunk between the two.On the server switch two vlans were configured (vlan08 & vlan14), ports 2 - 5 were assigned to vlan 8 & ports 6 - 10 to vlan 14. Because a trunk is configured between the two switches if I am logged in to the client switch I can view the vlan membership on the server switch.
I now want to assign a number of ports on the client switch to vlan 8, how is this done??
Must you take the client out of client mode to assign ports?? How will the new vlan membership be displayed if you use the "show vlan" command from the client switch??
2 Accepted Solutions
Amit Singh
You can assing ports to any vlan on the client switch. You cannot create/delet the vlan while the switch is in VTP client mode.
To assign a number of ports to a particular vlan you can use the " range " command on the switch. Do the following:
Conf t
interface range fa0/1 - 10 <- there is a space between the numbers and -
switchport mode access
switchport access vlan XX <- vlan number
You can use " show vlan " command on the client switch to see the vlan membership
HTH,Pleae rate if it does.
-amit singh
walleyewiz
you can run the following command to add ports to the correct vlan:
interface x/x
switchport access vlan 401
no logging event link-status
I assume you are talking about vtp client and server mode? You don't need to change the mode on the switch.
Also, VTP should be run in transparent mode--at least that is what most people recommend.
Amit Singh
Conf t
-amit singh
Hello again
I have assigned ports on the client switch to vlans & used the "show vlan" command to confim & it shows the assignments, however when I log out of the client switch & then log back in & use the "show vlan" command again it no longer shows the assignments I had just made; can you tell me why this is??
walleyewiz
interface x/x
Vishwa.Mishra
Add to all the reply
VTP do not carry information about what ports are assigned to vlan ,that is a local information to the switch,so to assign port to a client it could be done in normal way.
