VLAN creation in WS-C2948G-L3 ?
ribin.jones
I just bought a Cisco layer 3 switch (model Number: WS-C2948G-L3) from ebay and my intend is to create VLAN's in this. But strangely enough, I don't see any commands to create vlans. but I see the command sh vlans.
I think this switch is loaded with Cat OS and so I tried to create vlan's using set command, but seems the switch doesn't take this command.
Router#set?
set  setup
But,
Router#set ?
% Unrecognized command
Find the below output of show version and show bootflash commands:
Router#sh bootflash:
Boot flash directory:
File  Length   Name/status
  1   3183128  cat2948g-in-mz.120-7.W5.15d.bin
[3183192 bytes used, 13594024 available, 16777216 total]
16384K bytes of processor board Boot flash (Read/Write)
Router#sh ver
IOS (tm) L3 Switch/Router Software (CAT2948G-IN-M), Version 12.0(7)W5(15d)  RELE
ASE SOFTWARE
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 05-Jun-00 16:16 by integ
Image text-base: 0x60010928, data-base: 0x605B8000
ROM: System Bootstrap, Version 12.0(7)W5(15a) RELEASE SOFTWARE
Router uptime is 17 hours, 38 minutes
System restarted by power-on
System image file is "bootflash:cat2948g-in-mz.120-7.W5.15d.bin"
cisco Cat2948G (R5000) processor with 49152K/16384K bytes of memory.
R5000 processor, Implementation 35, Revision 2.1
Last reset from power-on
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3z interface(s)
121K bytes of non-volatile configuration memory.
Configuration register is 0x2142 (will be 0x2102 at next reload)
I know this switch is out of sale and cico doesn't support this switch also. Do I need to have a different firmware installed, to get VLAN's created?
Any help greatly appreciated.
Thanks in advance,
Ribin
2 Accepted Solutions
try this
2948G-L3#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
2948G-L3(config)#bridge irb
!create vlan 10
2948G-L3(config)#bridge 10 protocol ieee
2948G-L3(config)#bridge 10 route ip
2948G-L3(config)#interface bvi 10
2948G-L3(config-if)#ip address 10.1.1.1 255.255.255.0
2948G-L3(config-if)#exit
!assign vlan 10 to fast 1
2948G-L3(config)#interface fast 1 2948G-L3(config-if)#no shutdown 2948G-L3(config-if)#bridge-group 10
detail see
http://www.cisco.com/en/US/products/hw/switches/ps672/products_tech_note09186a0080093f8f.shtml#ex1
Hi Ribin
I think here you need to configure a BVI Interfaces with the IP you want.
Example Interface:
Router(config)# interface fastethernet 2.1
Router(config-subif)# encap isl 50
Router(config-subif)# bridge-group 1
bridge-goup 1 is interfave BVI 1 in BVI 1 you specified the IP.
Example BVI:
Router(config)# bridge irb
Router(config)# interface bvi bridge-group
Router(config-if)# ip address ip-address ip-address-subnet-mask
Router(config-if)# exit
Router(config)# bridge bridge-group route protocol
Detail informations here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2948gand4908g/12.0_18_w5_22a/configuration/guide/bridging.html
Hope that is the key for you.
- Sebastian
16 Replies 16
glen.grant
   That is a native IOS box so try creating them the way you would on a normal IOS box .  I haven't worked on one of the L3 versions only the L2 versions which were catos and used set based commands .   Great way to search for this stuff is to just go to the main cisco.com webpage and do a search for what you want to do .
http://www.cisco.com/en/US/products/hw/switches/ps606/products_configuration_guide_chapter09186a008007d102.html#xtocid263693
conf t
vlan 20
name -  xxx.xxx.xxx.xxx/mask
int vlan 20
ip address xxx.xxx.xxx.xxx mask
I am not able to enter any of the vlan commands. I tried some of the commands in http://www.ciscopress.com/articles/article.asp?p=29803.
I tried as you mentionedalso.
Router#conf t
Router(config)#vlan?
%Unrecognized command.
How can I proceed from here?
- Ribin
try this
!create vlan 10
detail see
I can enter these commands in the switch. But how can I create vlan's?
- Ribin
bridge 10 is vlan 10.
show vlans
Below is my config:
sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
bridge irb
interface FastEthernet1
no ip address
no ip directed-broadcast
bridge-group 10
interface FastEthernet2
shutdown
interface FastEthernet3
no ip address
shutdown
interface BVI10
no ip route-cache cef
ip classless
bridge 10 route ip
line con 0
transport input none
line aux 0
line vty 0 4
end
Nothing shown in sh vlan:
Router#sh vlan
No Virtual LANs configured.
Router#
- Ribin
Do you have device connect to fast port 1?
If I remember right ( 12 years ago), bridge can not up/up until that port actived.
I connected a laptop to fastethernet 1. But still no luck it seems...
Router#sh ip int bri
Interface                  IP-Address      OK? Method Status                Prot
ocol
FX1000:1                   unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  administratively down down
FastEthernet3              unassigned      YES unset  administratively down down
FastEthernet4              unassigned      YES unset  administratively down down
FastEthernet5              unassigned      YES unset  administratively down down
FastEthernet6              unassigned      YES unset  administratively down down
FastEthernet7              unassigned      YES unset  administratively down down
FastEthernet8              unassigned      YES unset  administratively down down
FastEthernet9              unassigned      YES unset  administratively down down
FastEthernet10             unassigned      YES unset  administratively down down
Router#sh vlan
Router#
- Ribin
Any other option I should try out?
I think the issue with the firmware I am having. Please correct me if I am wrong. Could someone let me know the actual firmware version which will work in this switch for vlans?
- Ribin
No more help/suggestions?
- Ribin
Like I see in some old documentations you can't use the "known" IOS vlan commands.
I prefer the 802.1q configuration and I would say try it, hope that helps
please look here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2948gand4908g/12.0_18_w5_22a/configuration/guide/vlan_cnfg.html
best regards,
Sebastian
Hi Sebastian,
In the mentioned doc, I was going through "Configuring ISL VLAN Encapsulation" and Figure 5-2     An ISL VLAN Bridging Configuration.
It talks about vlan 50 and vlan 100.Where do I give IP address for vlan's?
- Ribin
Hi Ribin
Example Interface:
Example BVI:
- Sebastian
Great..It worked.......Thanks Sebastian
- Ribin
