VLAN creation
MouhatNicolas
I have a 1841 router and I want to create a VLAN with the ID 2002.
I use an IOS that supports extended VLAN, but when I try to create the VLAN, the command "vlan id" doesn't work.
9 Replies 9
mahmoodmkl
Level 7
Level 7
I think u have to create it in the vlan-database.
router#vlan database
vtp transparent
vlan 2002 name ()
Mahmood
In the VLAN database I'm limitated to the id <1-1005>.
try it in global mode but u r VTP mode should be transparent.
Mahmood
The VTP is already configured in trasparent mode but I can't find the command to create the VLAN in global mode.
As I said, the command "vlan id" doesn't work.
have you enable the Extended System ID ?
if not try enableing it and check.
You should be aware of the network before dooing so.
let me know if that works
I tried the command "spanning-tree extend system-id" but the command is unknown.
can you provide me the ios verison and feture set information
I was using the IOS c1841-advipservicesk9-mz.12.4-11.XW2 and I just change to IOS c1841-advipservicesk9-mz.12.4-11.XJ4.
Now it is working.
I compared the fonctionnalities of the two IOS and the one that doesn't work has all the fonctionnalities of the one that is working.
Has anyone an explanation?
I would not able to go indepth with the ios.
The only thing i can say is the feature set.
Well let me tell u one more thing there some ios feature set does not support radius server you need to change the fetureset of the ios verion to get this command working.
thats nice to know that it working.
