Vlan.dat backup in 6513 catos
rangaswamy.gb
How we can take backup of vlan.dat and config using tftp in catos based 6513 switch
5 Replies 5
Collin Clark
You need to find where the file is. You can try a dir /all. Then copy from that disk to your tftp server.
SWITCH12#dir /all
Directory of disk0:/
1 -rw- 107998 Feb 24 2008 23:23:58 -06:00 running-config
2 -rw- 5716 Feb 24 2008 23:25:18 -06:00 vlan.dat
6 -rw- 78316036 Jan 29 2009 12:52:10 -06:00 s72033-advipservicesk9_wan-mz.122-33.SXH4.bin
SWITCH12#copy disk0: tftp:
Source filename []? vlan.dat
Address or name of remote host []? 10.1.2.17
Destination filename [vlan.dat]?
PGI_6513> (enable) dir /all
No such file
25939972 bytes available (6041596 bytes used)
PGI_6513> (enable) copy disk0: tftp:
Invalid file id disk0:
PGI_6513> (enable)
Try just dir
Edison Ortiz
Unlike Native IOS, the vlan information is visible in the running configuration on any VTP mode so if you are backing up the running configuration, you are also backing up the Vlan information from the switch.
On Native IOS, the Vlan information is only visible in the running config while the VTP mode is set to transparent.
And the command to backup the config is:
copy config tftp
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/d_cmd.html#wp1025320
HTH,
__
Edison.
-#- -length- -----date/time------ name
1 6041468 May 06 2005 03:35:42 cat6000-sup2k8.7-1-2.bin
PGI_6513> (enable) pwd
bootflash
PGI_6513> (enable) cd slot0:
slot0
error = -8
Open device slot0 failed (no device)
PGI_6513> (enable) cd nvram:
Invalid device
PGI_6513> (enable)
