Community Member
VLAN-enabled layer 3 switch
can you recommend a cisco switch for small office of 20 workstations + servers all together?
1 REPLY
Re: VLAN-enabled layer 3 switch
Phong,
A 3560 24 port switch should do the job for you. If you need gigabit connectivity you will want the 3560G-24 port switch. There is also a 48 port model if you plan for future expansion.
HTH,
Mark
115
