VLAN for Voice on Cisco 3750
Please bear with me. I may be asking a simple question but the bottom line is I need some help.
I have a single Cisco 3750 POE Switch  (10/100Mbps) and a Cisco 2901 Router (CME).
My data network is on 192.168.5.0/24 (VLAN 500) and Voice on 192.168.4.0/24 (VLAN 400). The DHCP Server is on a WIndows Server (192.168.5.4). The CME router is on port 2 (int F4/0/2), the DHCP on port 3 and the firewall (192.168.5.1) on port 1. the user computers connection to the network via the Cisco 7945 IP Phones.
I would like to Configure the VLAN for VOICE and DATA including interVLAN routing.
I would need some sample configuration to help me started.
davison.
1 ACCEPTED SOLUTION
Green
Davison
This should get you started
vlan 400
name VOICE
vlan 500
name DATA
ip routing
int vlan 400
desc *** VOICE ***
ip add 192.168.4.254 255.255.255.0
ip helper-address 192.168.5.4
no shut
int vlan 500
desc *** DATA ***
ip add 192.168.5.254 255.255.255.0
no shut
ip route 0.0.0.0 0.0.0.0 192.168.5.1
int f0/1
desc *** FIREWALL ***
switchport mode host
switcport access vlan 500
int f0/2
desc *** CME ***
switcport access vlan 400
int f0/3
desc *** DHCP ***
in f0/4
desc *** PHONE WITH PC ***
switcport voice vlan 400
in f0/5
etc etc
vlan 400
name VOICE
vlan 500
name DATA
ip routing
int vlan 400
desc *** VOICE ***
no shut
int vlan 500
desc *** DATA ***
no shut
int f0/1
int f0/2
desc *** CME ***
int f0/3
desc *** DHCP ***
in f0/4
in f0/5
etc etc
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Green
Davison,
Is the CME to used for inter vlan routing or the 3750.
Alex.
Hi Alex,
The Intervlan routing will be on the 3750 switch (48 port). you offer the best way to do it.
thanks.
regards,
Davison
Green
Davison
vlan 400
name VOICE
vlan 500
name DATA
ip routing
int vlan 400
desc *** VOICE ***
no shut
int vlan 500
desc *** DATA ***
no shut
int f0/1
int f0/2
desc *** CME ***
int f0/3
desc *** DHCP ***
in f0/4
in f0/5
etc etc
vlan 400
name VOICE
vlan 500
name DATA
ip routing
int vlan 400
desc *** VOICE ***
no shut
int vlan 500
desc *** DATA ***
no shut
int f0/1
int f0/2
desc *** CME ***
int f0/3
desc *** DHCP ***
in f0/4
in f0/5
etc etc
Alex.
Hi Alex,
thanks alot. Will try that and will let you know.
Best regards,
Davison
Hi Alex,
That did the trick. thanks so very much. The world is a much better place with people like you.
My CME is up and running with phone ringing!
thank you.
regards,
Davison
107
