VLAN ID
I have a problem with my 2950 switch. Basically, I have a custom made device which has two ports with the same MAC-address (not desirable to change it). There also exists a client with two ports (device_port1 <--COM--> client_port1, device_port2 <--COM--> client_port2) that communicates with this device, and I would the switch to manage the traffic.
I have tried to setup two VLAN's; VLAN_port1 and VLAN_port2, and also static MAC addresses for VLAN_port1 so that packets are forwarded correctly to device_port1 (no ARP-server); and vice versa for VLAN_port2.
The problem is that packets received on device_portx is injected with a VLAN_ID field in the ethernet header, which the device can not interpret. Is it possible to disable this injection ? I just want to "split" the switch.
Thanks in advance.
Re: VLAN ID
It seems that just configuring your ports as "access" versus trunks should be the solution to your problem:
switchport mode access
switchport access vlan XXX
(where XXX is VLAN_port1 or VLAN_port2).
The static mac address should not be necessary.
Francois
Silver
Re: VLAN ID
Marcus,
I don't know if I understood your situation but what I can see you need to creat two VLANs which you did. THen assign
Device_port1 and Client_Port 1 to same VLAN100
Device_port2 and Client_port 2 to same VLAN200
The VLAN_ID should not affect the port. Treat the port as normal LAN interface.
I don't know if I could help,
Please let me know,
103
