vlan interface administratively down
brad.thurston
I just created a vlan, assigned it to a port on our 6509, assigned the vlan an ip address and when i shoot the command, show int vlan 31 it says that the vlan is administratively down. I can't figure out whats going on here? i issued a no shut, to no avail.
7 Replies 7
royalblues
Level 10
Level 10
For the VLAN interface or the SVI to come up, you should have atleast one port connected to that VLAN or you should have a trunk configured in that switch
HTH, rate if it does
Narayan
will it not come up if stp does not exist on the vlan
guruprasadr
Level 7
Level 7
HI Brad.Thurston,
Try connecting some device/PC to the VLAN Port & can you please check the same.
Pls Rate if Helps ! !
Best Regards,
Guru Prasad R
Thanks guys for your help, I got stp going on the port. after a few seconds for propagation im sure, it came up
Brad,
You mean to say you had disabled STP on the switch?
no, but it wasn't showing for that vlan interface
glen.grant
You need at least one active interface on that vlan , whether it is a user pc or just having the vlan included in a trunk in order for the layer 3 SVI come up , this due to the autostate function of the switch . Make sure the layer 2 vlan is created with the show vlan command.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
