VLAN Interface Down on PIX/FWSM
We added a new vlan (vlan5) in an FWSM context with "nameif inside1" and IP address of 10.10.1.1 mask 255.255.255.0. Routes are set on the router. The interface and line protocol are shown as down. A "no shut" does not enable the interface.
Help? Thanks...
Hall of Fame Super Blue
Re: VLAN Interface Down on PIX/FWSM
Have you added vlan 5 to the switch chassis ie.
firewall vlan-group 1 5
Obviously you need to modify the above to match what you alrady have.
Jon
The vlan was already added to the firewall vlan-group. I should've mentioned it earlier.
Thanks.
Hello
dit you add the interface in the system context :
allocate-interface vlan5
Yes, the new vlan has been allocated.
Thanks.
Hello
is the vlan5 created in the switch chassis ie.
If not you will see on the context
> sh int
Interface vlan5 "inside1", is administratively down, line protocol is down
Available but not assigned from Supervisor
greetings
1133
