11-14-2007 05:00 AM - edited 03-05-2019 07:25 PM
Hello
Is there a way to force a SVI Vlan Interface up if no physical link is connected.
Best regards
Gerhard
11-14-2007 05:54 AM
Gerhard
Try configuring a trunk on the switch that includes that VLAN.
Ric
11-14-2007 08:11 AM
Hi Gerhard, try the following commands:
int vlanXXX
vlan XXX
I have used this in the past and it tends to bring the vlan ints up.
regards,
Raj
12-05-2011 05:31 PM
config terminal
interface Vlan1
ip address 192.168.0.1 255.255.255.0
no autostate
no shutdown
interface Vlan2
no autostate
no shutdown
interface Vlan3
ip address 192.168.2.1 255.255.255.0
no autostate
no shutdown
int range FastEthernet0/1 - 8
switch access vlan 1
switch mode access
int range FastEthernet0/9 - 16
switch access vlan 2
switch mode access
int range FastEthernet0/17 - 24
switch access vlan 3
switch mode access
end
produces the following results with all ports unplugged.
02-06-2013 07:38 AM
What IOS version supports the autostate command? I just loaded 15.0(2)SE IP base on a 3560v2 and this interface command is not available.
-Jeff
12-06-2011 01:34 AM
take a look here: http://blog.ioshints.info/2009/07/followup-vlan-interface-status.html
Regards.
Alain
02-06-2013 07:46 PM
i think u have ti type it
