VLAN IP address
Eric Tan
hi all, may i ask something on VLAN IP address.
is it necessary to assign IP address to VLAN beside you need to do routing on Layer 3  ?
Say i create Vlan 192 => 192.168.1.x /24
All the servers uses static IP. I have a load balancer assign as 192.168.1.1
If i assign the IP range to Vlan 192, there will be a log about mac address duplication.
So do I change the Vlan IP to 192.168.1.2 instead ?
is there any implication ?
Jon Marshall
If you do not assign an IP to the L3 vlan interface (SVI) for that vlan then you cannot route that vlan.
You can assign any IP from the subnet range to the SVI.
It's not clear exactly what you are asking though. You have a load balancer using 192.168.1.1, is that device in vlan 192 ?
Jon
Yes the LB is in same Vlan 192. I guess I got the duplicate error when i assign Vlan 192 as
192.168.1.1.
The implications are that any devices which live on that vlan + want to route traffic to a different subnet, need to be configured with the svi ip address as their default gateway. i.e. if you change the svi ip address without changing the host's default gateway address, you will stop these hosts from reaching remote destinations..
Please excuse me if I have not understood your requirements properly.
Mike
Hello
if you mean having these devices in that specific ip range just connect to each other then there is no need for a L3 vlan, they just need to be in the same L2 vlan.
But as Jon stated if you need these devices to connect to other vlans then you will need a l3 interface  be it an SVI on a L3 switch or a router to perform the routing.
res
Paul
Kind Regards
Paul
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
