vlan mismatch frequently i can't ping default gateway
yogeshtayade
Parvesh Paliwal
Level 3
Level 3
share the logs
Parvesh
devils_advocate
Level 7
Level 7
You need to give us more information.
Correct the Vlan mismatch for a start, the message on the console should tell you which side is incorrect.
Then diagram your setup and share the configs and we can help troubleshoot.
