Webcast-Catalyst9k
Vlan need not to communicate to one perticular Vlan
I have a question on Vlan communications.
I have a scenario where in i have 5 Vlans ( Vlan 1,2,3,4,5) in my switch, and my requirment is that i don want the VLAN 3 and Vlan 4 to communicate to each other. where as all other vlans except Vlan3 should communicate to Vlan4 and vice versa  ....and all vlans except 4 should communicate to Vlan3 and vice-versa...
Please reply me with the logic and neccesary cammands.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Vlan need not to communicate to one perticular Vlan
azharuddininamdar wrote:
Hi Jon,
Thanks a ton for this info..
Can i implement the same using distribute list?
No, distribute lists are used primarily for filtering inbound or outbound routing updates. If you want to restrict traffic between vlans then acls are the way to go.
Jon
vlan 3 = 192.168.5.0/24
vlan 4 = 192.168.6.0/24
access-list 101 deny ip 192.168.5.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 102 deny ip 192.168.6.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 102 permit ip 192.168.6.0 0.0.0.255 any
int vlan 3
ip access-group 101 in
int vlan 4
ip access-group 102 in
Jon
Hi Jon,
Hi Jon,
Jon
Got it Jon,
I was known to this, but needed to confirm..
thanks for resolving my Query...
170
