Vlan on notepad
alsayed
if i want to creat the L2 vlan on the notpad than paste it into the core;
e.g vlan 10 name test
vlan 11 name best
can i do this:
regards
Ali
You dont need to write ENTER.
vlan 10
name test
5 Replies 5
Rather, this should work:
vlan 10
name test
vlan 11
name best
Hi pthiagas!
do i need to write this: or
vlan 10
name test
vlan 10
name test
Ali,
What you have in your original posting should work. Here is the output from a 3550 switch.
SW1-3550#vlan database
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
SW1-3550(vlan)#vlan 10 name test
VLAN 10 added:
SW1-3550(vlan)#vlan 11 name best
VLAN 11 modified:
SW1-3550(vlan)#exit
APPLY completed.
Exiting....
BTW, don't forget to type in exit to logout to save the config.
Sundar
HI Sundar
10xs for ur reply
ALI
