Bronze
vlan problem
3 systems linked to same vlan.This vlan is present in 2 different switches. One of the systems located in the 2nd switch is unable to talk to the systems in the first switch within the same vlan.
2 systems out of this on the same switch under same vlan have no issues. But the problem is for the 3rd system to connect to the first 2 systems over the same vlan but on different switch.
Pls suggest.
Thanks in advance!!!
Re: vlan problem
can u confrim weather u have a trunk link between the switches.
Mahmood
Community Member
Re: vlan problem
Do a sh int trunk on both switches. Is the vlan in question being allowed on the trunk? Does the vlan exist in the vtp database on each switch?
Bronze
Re: vlan problem
yep ..it exists on the vtpdatabase.I have a smal query here.
Will similar vlans need to be allowed in the trunk if they exist on either side of the two switches?
Hall of Fame Super Blue
Re: vlan problem
Your trunk should have the same set of allowed vlans on both switches.
Jon
Bronze
Re: vlan problem
yep..it has all vlans allowed betn the trunks
Re: vlan problem
Okay, so
1) Vlan exists on both switches
2) Trunk link is up and allows that vlan across it.
3) Ports on both switches are allocated into same vlan.
4) You have correctly specified IP address/subnet masks on all 3 devices.
5) There is no firewalling software on any PC that could be stopping traffic.
Jon
Bronze
Re: vlan problem
Yes..all dese have been checked n appears to be fine.Just wondering cud there be any spanning tree issue involved here??
Re: vlan problem
Do you have multiple connections between these 2 switches then ?
If not it is unlikely to be spanning tree that is causing the issue.
Jon
Community Member
Re: vlan problem
To verify this
from the switch do the following
1) Make sure you have trunking enabled over ISL or dot1q
config t
interface
switchport trunk enable
switchport mode trunk encap isl
allow the necessary vlan to pass over the trunk
allowed vlans
This should fix the issue HTH
Community Member
Re: vlan problem
Also I know you have already checked probably but is the interface associated with vlan in Layer2 mode
switchport mode access
switchport access vlan.
Just wanted to make sure
Also check to see if you are having any spanning tree issues
show spantree
Re: vlan problem
Please check if the same VLAN is configured as the native VLAN.
Check for Native VLAN mismatch.
-> Sushil
Bronze
Re: vlan problem
Will be checking this tommorrow.BTW how would native vlan create an issue with access??
Bronze
Re: vlan problem
How will the spantree status with varied port states help to identify if there is any loops occuring in the network/the vlan?
166
