02-01-2007 10:37 AM - edited 03-05-2019 02:07 PM
Which command is used to define a VLAN range (subnet) on a remote switch which is gegraphically separated from the VTP SERVER.
02-01-2007 11:08 AM
I suppose both switchs reside in the same VTP domain. If the switch in question is a vtp client, then you must define the vlan on the server. In transparent mode you can define a vlan, but it will only work on that switch.
Which version of VTP do you use anyway ?
02-01-2007 12:47 PM
i want to know on how to enable ip range on the vtp server for a remotely located vtp client.
how to enable communication between two vlans whcih are in different domains?
