VLAN routing between 3 x L2 switches
I have LAN 3 x 2960 L2 switches in a triangle typology gives me some redundancy, I have 1 switch as the VTP server and the other 2 as VTP clients and only have 3 vlans that all the switches are using.  For the 3 vlans to route between each other do I need a router and use it as a router on a stick?  If so I'm not sure where to place it so all 3 switches can route between each other.
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: VLAN routing between 3 x L2 switches
Whiteford wrote:
That makes sense.  I have a router in one switch already, it's in vlan 20 on one of the switches:
interface FastEthernet0/0
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
Would I simpley remove this and add something like:
interface FastEthernet0/0.20
encapsulation dot1Q 10
  duplex auto
  speed auto
interface FastEthernet0/0.30
  ip address 192.168.30.1 255.255.255.0
  duplex auto
  speed auto
etc?
Yes you would but note that the encapsulation command under the subinterface must match the vlan id so if you had vlans 20 and 30 using your above example -
encapsulation dot1Q 20
  duplex auto
  speed auto
encapsulation dot1Q 30
  duplex auto
  speed auto
the actual subinterface number does not have to match the vlan id but it is easier to read if it does.
Jon
You either need a router and do routing on a stick or a better solution is to use a L3 switch.
As for placement just connect the router to one of the switches with a trunk that allows all 3 vlans and create subinterfaces on the router. As long as all the switches are connected together with L2 trunks allowing all vlans it doesn't matter which switch you connect the router to.
Jon
duplex auto
speed auto
  duplex auto
  speed auto
  duplex auto
  speed auto
etc?
duplex auto
speed auto
  duplex auto
  speed auto
  duplex auto
  speed auto
etc?
  duplex auto
  speed auto
  duplex auto
  speed auto
Jon
Great that is all working now.
394
