VLAN Routing Configuration
I've seen some configs showing the use of subinterfaces to perform vlan routing. If I am using a layer 3 switch, is it a safe practice to create a vlan interface and put an IP on it?
I guess I don't understand the difference between the two. On a layer 3, couldn't I take the trunk from another switch and plug it into the layer 3 switch, then put an IP on that interface and issue the "no switchport" command?
What's the difference between creating the vlan subnet on a physical interface as opposed to creating an svi vlan interface?
Blue
Re: VLAN Routing Configuration
Jason:
The first scenario you give is called a "router-on-a-stick" and that consists of connecting a layer 2 switch, with multiple vlans configured on it, to a L3 switch or router via a trunk.
The router will be responsible for inter-vlan routing. The ethernet interface of the router will be configured with subinterfaces to support a routed connection for each vlan. One of the benefits of this is that you only need to use one router interface to support multiple vlans.
Here is a sample router-on-a-stick configuration:
Switch Config:
vlan 100
HR_vlan
vlan 200
First_Floor_users
interface fastethernet 1/0/1
description To_router_fa0/0
switchport
switchport mode trunk
Router config:
interface fastethernet 0/0
description To_L2_Switch_fa1/0/1
no ip address
interface fastethernet 0/0.1
encapsulation dot1q 1 native
interface fastethernet 0/0.100
encapsulation dot1q 100
ip address 192.168.100.1 255.255.255.0
interface fastethernet 0/0.200
encapsulation dot1q 200
ip address 192.168.200.1 255.255.255.0
And the you have the SVI method, as follows:
L2 switch config:
vlan 100
HR_users
vlan 200
First_floor_users
interface gigabitethernet 0/48
description Trunk_to_L3_Switch_Gi1/1
switchport
L3 Switch config:
vlan 100
HR_vlan
vlan 200
First_floor_users
interface gigabitethernet 1/1
description Trunk_to_User_switch_Gi0/48
switchport
inetrface vlan 100
description HR vlan
interface vlan 200
description First_floor_users
Router eigrp 100
network 192.168.100.0 0.0.0.255
network 192.168.200.0 0.0.0.255
Please rate this post if you found it informative and helpful.
Victor
Hi Jason,
When you make a physical interface a routed port with the "no switchport" command, you have a port like a normal router has.
The exception to this is that on layer3 switches you cannot create subinterfaces on physical ports.
When you leave your physical port in the layer2 state, then that port may function as a layer2 access port or a layer2 trunk port, depending on the switchport configuration.
So your layer2 ports will be participating in layer2 switching, and you can even configure a set of ports as access ports on your switch and they will function as a separate layer2 switch with their own vlan.
In this case you can create the vlan interfaces and use them for routing safely. They behave very much like a physical interface.
For example, if you have vlan 1, vlan 2 and vlan 3, then you can create interfaces vlan1, vlan2 and vlan3.
When one of your physical interfaces are configured for trunking and carries vlan1, vlan2 and vlan3 traffic, then the traffic of different vlans will be separated and directed to the appropriate vlan interfaces for routing if necessary.
So traffic from vlan1 will be routed by interface vlan1, and so on.
You can apply routing, access-lists, qos, and other features to vlan interfaces as with normal physical interfaces.
This gives you more flexibilty in your configurations.
Cheers:
Istvan
214
