VLAN routing issue
I have a C857w on a remote location and the users cannot ping the default gateway, yet they can gain access to the Internet.  The routing has a VLAN setup and in the configuration there is a command line of:
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.5.0 0.0.0.0 Dialer 1
My question is shouldn't VLAN1 be in place of the Dialer1? The other network is over a IPSEC L2L VPN Connection.
  • LAN Switching and Routing
1 REPLY
Re: VLAN routing issue
I am assuming that dialer1 is connected to your ISP. In that case, what you
are seeing is correct. Your default gateway points to the Dialer1 interface.
Since the IP of the default gateway is not known, you are pointing your
default route to the outgoing interface. VLAN1 is significant for your
internal networks only. It will not show up on the route statement for
external (internet) routes. As far as pinging the default gateway is
concerned, are you talking about ISP default gateway? Sometimes, the ISP
will block ICMP traffic to protect their network from attacks. You might
want to first find the default gateway address and also find out if they
have allowed ICMP.
Hope this helps.
NT
189
