vlan routing
Hi. I configured my router interface for vlan routing. However I am unable to ping any of these subinterfaces from the router itself and when i run: sh ip int brief, it shows e0 as up up but e0.1 and e0.2 as down.
The config of the interface is shown below.
int e0
no shut
int e0.1
ip add 10.0.1.1 255.255.255.0
encap dot1q 2
no shut
int e0.2
ip add 10.0.2.1 255.255.255.0
encap dot1q 3
no shut
When i go to check e0.1 or e0.2, it shows a status as up but protocol down. e0 is physically connected to a switch port f0/12. The config is shown below.
int f0/12
switchport mode trunk
switchport trunk encap dot1q
no shut
This switch has two vlans- 2 and 3. Also, i checked the BW of f0/12 and e0 and found it to be set to 10MB. I manually set the bandwidth of e0.1 and e0.2 to 10MB as well but still no go.
I do hope someone can help me with this. Thanks.
Silver
Re: vlan routing
Have you created the vlan's themselves on the switch, are they in the vlan database if you do a show vlan?
If not, type conf t, vlan2, exit, vlan3
Silver
Re: vlan routing
Hi ,
Can you change the config as below and check the status of interfaces.
int e0
no shut
int e0.1
encap dot1q 2 native
no shut
int e0.2
encap dot1q 3
no shut
Switch :
interface vlan 2
ip address 10.0.1.253 255.255.255.0
no sh
int f0/12
switchport trunk native vlan 2
speed 100
duplex full
no shut
ip default-gateway 10.0.1.1
Satish
Re: vlan routing
Hi Satish. Just wish to ask: shouldn't i be able to ping e0.1 and e0.2 from the router?
Re: vlan routing
Hello Mark,
Can you share with us IOS image information on router?
Padmanabhan
258
