Vlan Span to a port in 6513
whats the command to span entire vlan to a particular port. the IOS version is 12.2(18)SXD6. set commands doesnt work.
AJ
Re: Vlan Span to a port in 6513
Hi Aj,
Its an IOS to you have to use IOS base command and not set base command
Router(config)# monitor session local_span_session_number source {{single_interface | interface_list | interface_range | mixed_interface_list | single_vlan | vlan_list | vlan_range | mixed_vlan_list} [rx | tx | both]}}
Router(config)# monitor session local_span_session_number destination {single_interface | interface_list | interface_range | mixed_interface_list}
Have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/span.htm#wp1089465
Ankur
Hi Ankur,
Yes. The answer solved the purpose. Thanks.
AJ
192
