01-28-2009 10:45 PM - edited 03-06-2019 03:44 AM
Hello experts,
Since there is no way to change the topic i repost this conversation here.
I have this problem:
3 switches - 1 - 4503 and 2 - 3750
They run in a cluster.
There is one 802.1Q trunk from each 3750 to the 4503.
On the 4503 i create 2 VLANs with SVIs.
VLAN 2 - 20.0.0.1/24
VLAN 3 - 30.0.0.1/24
and the default one
VLAN 1 - 192.168.1.x
All interfaces are up/up
Management IP addresses of switches are as follows:
4503 - 192.168.1.2
1st 3750 - 192.168.1.3
2nd 3750 - 192.168.1.4
And here is the problem:
I disable all routing as you may see in the configuration bellow and all VLANs have connection to each other through the SVI.
Generally I want VLAN 2 to have access to VLAN 1, VLAN 3 to have access to VLAN 1 but restrict access form VLAN 2 to VLAN 3.
Any help will be appreciated, thanks!
Current configuration : 2533 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service compress-config
service sequence-numbers
hostname Catalyst4503
boot-start-marker
boot system flash bootflash:cat4000-i5s-mz.122-25.EWA12.bin
boot-end-marker
no logging console
enable password **********
no aaa new-model
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct
qos dbl
qos map dscp 24 25 26 27 28 29 30 31 to tx-queue 4
qos map dscp 32 33 34 35 36 37 38 39 to tx-queue 4
qos map cos 3 to dscp 26
qos map cos 5 to dscp 46
qos
ip subnet-zero
no ip routing
no ip domain-lookup
cluster run
cluster enable NRS 0
cluster member 1 mac-address 001e.bee6.3e80
cluster member 2 mac-address 001e.f756.6780
no file verify auto
spanning-tree mode pvst
power redundancy-mode redundant
vlan internal allocation policy descending
policy-map autoqos-voip-policy
class class-default
dbl
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet2/1
interface GigabitEthernet2/2
interface GigabitEthernet2/3
switchport mode trunk
switchport nonegotiate
service-policy output autoqos-voip-policy
qos trust cos
auto qos voip trust
tx-queue 3
priority high
shape percent 33
macro description cisco-switch
spanning-tree link-type point-to-point
interface GigabitEthernet2/4
qos trust cos
auto qos voip trust
tx-queue 3
priority high
shape percent 33
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
interface GigabitEthernet2/10
interface GigabitEthernet2/11
interface GigabitEthernet2/12
interface GigabitEthernet2/13
interface GigabitEthernet2/14
interface GigabitEthernet2/15
interface GigabitEthernet2/16
interface GigabitEthernet2/17
interface GigabitEthernet2/18
interface Vlan1
ip address 192.168.1.2 255.255.255.0
no ip route-cache
interface Vlan2
ip address 20.0.0.1 255.255.255.0
no ip route-cache
interface Vlan3
ip address 30.0.0.1 255.255.255.0
no ip route-cache
interface Vlan6
ip address 60.0.0.1 255.0.0.0
no ip route-cache
shutdown
ip http server
line con 0
stopbits 1
line vty 0 4
password test
login
length 0
end
Catalyst4503#
Catalyst4503#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Catalyst4503(config)#no ip routing
Catalyst4503(config)#end
Catalyst4503#write
Building configuration...
01-29-2009 12:23 AM
did you try to use access-lists?
why did you disable routing? that's has no sens to disable routing and having many l3 interfaces at the same time.
01-29-2009 03:43 AM
No, but after you pointed me to that method i managed to restrict InterVlan Communication by mean of VACL.
Thank you very much.
