Community Member
Vlan SVI trouble on Catalyst 4503 Cluster
Hello experts,
Since there is no way to change the topic i repost this conversation here.
I have this problem:
3 switches - 1 - 4503 and 2 - 3750
They run in a cluster.
There is one 802.1Q trunk from each 3750 to the 4503.
On the 4503 i create 2 VLANs with SVIs.
VLAN 2 - 20.0.0.1/24
VLAN 3 - 30.0.0.1/24
and the default one
VLAN 1 - 192.168.1.x
All interfaces are up/up
Management IP addresses of switches are as follows:
4503 - 192.168.1.2
1st 3750 - 192.168.1.3
2nd 3750 - 192.168.1.4
And here is the problem:
I disable all routing as you may see in the configuration bellow and all VLANs have connection to each other through the SVI.
Generally I want VLAN 2 to have access to VLAN 1, VLAN 3 to have access to VLAN 1 but restrict access form VLAN 2 to VLAN 3.
Any help will be appreciated, thanks!
Current configuration : 2533 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service compress-config
service sequence-numbers
hostname Catalyst4503
boot-start-marker
boot system flash bootflash:cat4000-i5s-mz.122-25.EWA12.bin
boot-end-marker
no logging console
enable password **********
no aaa new-model
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct
qos dbl
qos map dscp 24 25 26 27 28 29 30 31 to tx-queue 4
qos map dscp 32 33 34 35 36 37 38 39 to tx-queue 4
qos map cos 3 to dscp 26
qos map cos 5 to dscp 46
qos
ip subnet-zero
no ip routing
no ip domain-lookup
cluster run
cluster enable NRS 0
cluster member 1 mac-address 001e.bee6.3e80
cluster member 2 mac-address 001e.f756.6780
no file verify auto
spanning-tree mode pvst
power redundancy-mode redundant
vlan internal allocation policy descending
policy-map autoqos-voip-policy
class class-default
dbl
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet2/1
interface GigabitEthernet2/2
interface GigabitEthernet2/3
switchport mode trunk
switchport nonegotiate
service-policy output autoqos-voip-policy
qos trust cos
auto qos voip trust
tx-queue 3
priority high
shape percent 33
macro description cisco-switch
spanning-tree link-type point-to-point
interface GigabitEthernet2/4
qos trust cos
auto qos voip trust
tx-queue 3
priority high
shape percent 33
interface GigabitEthernet2/5
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
interface GigabitEthernet2/10
interface GigabitEthernet2/11
interface GigabitEthernet2/12
interface GigabitEthernet2/13
interface GigabitEthernet2/14
interface GigabitEthernet2/15
interface GigabitEthernet2/16
interface GigabitEthernet2/17
interface GigabitEthernet2/18
interface Vlan1
ip address 192.168.1.2 255.255.255.0
no ip route-cache
interface Vlan2
ip address 20.0.0.1 255.255.255.0
no ip route-cache
interface Vlan3
ip address 30.0.0.1 255.255.255.0
no ip route-cache
interface Vlan6
ip address 60.0.0.1 255.0.0.0
no ip route-cache
shutdown
ip http server
line con 0
stopbits 1
line vty 0 4
password test
login
length 0
end
Catalyst4503#
Catalyst4503#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Catalyst4503(config)#no ip routing
Catalyst4503(config)#end
Catalyst4503#write
Building configuration...
Silver
Re: Vlan SVI trouble on Catalyst 4503 Cluster
did you try to use access-lists?
why did you disable routing? that's has no sens to disable routing and having many l3 interfaces at the same time.
Community Member
No, but after you pointed me to that method i managed to restrict InterVlan Communication by mean of VACL.
Thank you very much.
143
