Webcast-Catalyst9k
Vlan syntax on 2924xl
hi all.
ive got a 2924c-xl switch with enterprise edition IOS, and Im trying to create a vlan on it. the syntax im using is:
switch1(config)#vlan 2
but i get an invalid error mesg.
can someone please help with the correct syntax?
Re: Vlan syntax on 2924xl
Try this-
Switch1# vlan database
Hall of Fame Super Blue
You may need to try vlan database mode ie.
switch# vlan database
and from ther you can configure your vlans.
** Edit - apologies Collin, posted and then saw your answer **
Jon
277
