Vlan Tagging and Config cant work!
I have a CISCO Router 1921 and i couldnt connect to the internet
The ISP have a tagged Vlan 10 on the internet before i could connect to it.
I have the below running config is there anything wrong with it?
additonal Info with a simeple routerr
Internet Connection:
IPv6 6rd:Disabled
IP Address:116.15.152.177
Subnet Mask:
Default Gateway:116.15.153.254
Primary DNS Server:165.21.83.88
Secondary DNS Server:165.21.100.88
Address:
   Subnet Mask:
   Host Name:
   Domain Name:
        Enable LAN side firewall
        Disable DHCP Server
        Enable DHCP Server
                 Start IP Address:
                 End IP Address:
                 Subnet Mask:
                 Leased Time (hour):
Running Config
no ip dhcp conflict logging
ip dhcp excluded-address 10.168.1.40 10.168.1.70
ip dhcp pool iptpool
network 10.168.1.0 255.255.255.0
default-router 10.168.1.254
dns-server 165.21.83.88 165.21.100.88
interface GigabitEthernet0/1
description LAN
ip address 10.168.2.1 255.255.255.0
ip address vlan 10
duplex auto
speed auto
no mop enabled
exit
interface GigabitEthernet0/0
description WAN
ip address dhcp
duplex auto
speed auto
interface vlan 10
name "SingtelFibre"
routing
ip address 10.168.1.1 255.255.254.0
ip route 0.0.0.0 0.0.0.0 202.166.71.254
ip access-list standard USC
permit 0.0.0.0
Bronze
Re: Vlan Tagging and Config cant work!
Your wan and lan adresses may need to be reversed?
I Guess the lan is where you want the router to distribute the dhcp scope.
So the lan interface adress should match the dhcp subiet.
I'm not sure, but you are assigned a default gateway from the ISP, yet you have a default route to a different next hop in your config. Remove the default route "ip route 0.0.0.0 0.0.0.0 202.166.71.254" and see if that resolves the issue.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Bronze
at first change
     description WAN
     ip address dhcp
     interface vlan 10
     name "SingtelFibre"
to:
     description physycal port
     no ip address
     interface GigabitEthernet0/0.10
     description WAN
     encapsulation dot1Q 10
     ip address dhcp
          ! or ip-address given by provider
This way tyou create, for the physical interface Gi0/0, a subinterface Gi0/0.10  that is vlan10 tagged
The interfacename Gi0/0.10 has only by name a relation with vlan10, You could use any number like Gi0/0.1 if you prefer.
then try to ping provider gatweway.
If that works, then we'll go to the next step
173
