vlan to vlan access port
Ok.  So this probably is a dumb question but I am going to ask it anyway.
Can you connect 2 switches on the same vlan as access ports?
for ex
sw 1
port 10 is on vlan 12
sw 2
port 10 is also on vlan 12
port 10 on both switches connect as uplinks.
Everyone's tags (2)
Yes you can...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
VIP Purple
Just think about a situation where you have two managed, but unconfigured switches in that scenario. There are all ports by default in vlan1 and are also access-ports. The result would be that all vlan1-ports on switch one can communicate with all vlan1-ports on switch two.
In your scenario all Vlan12-ports on switch one can communicate with all vlan12-ports on switch 2. Using the connection as a trunk would be better in many situations as you could add different vlans on both switches later and these could also communicate through the trunk.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
192
