VLAN to VLAN Communications
On our 4510 switch we have multiple VLANs. Two of the VLANs have IP addresses assigned to the VLAN interface. I assumed that no inter-VLAN communication would take place until I used the 'ip routing' command. That's not the case though. I do have communications between the two VLANs without this statement in place. We are using static routes but it does build the route to the directly connected interface. We also do not have a default route set on the switch.
From the documentation that I have read, you would need to enable 'ip routing' to route between VLANs but this doesn't seem to be the case.
Can someone clarify why this is happening?
Thanks!
1 ACCEPTED SOLUTION
Re: VLAN to VLAN Communications
Your ip routing is enable ;)
As already said , the ip routing is on by default and depending on the equipement , you not see the ligne no ip routing or ip routing.
Gregory
hello,
Can we have the output of the " show ip route " ?
Gregory
Here is the output:
4510#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.128.0/24 is directly connected, Vlan300
C 192.0.0.0/16 is directly connected, Vlan1
Ryan
Are you sure the ip routing is disable ?
Because when it's disable :
Router#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#no ip routing
Router(config)#exit
Router#show ip rout
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
Router#
there is a difference.
Gregory
I guess I am not sure if it is disabled or not. I don't see 'ip routing' in my config so I assumed it wasn't enabled.
Is it safe to assume that it is enabled however since I do have VLAN to VLAN traffic?
I don't want to issue the no command to test since I am in a production environment.
Thanks for your help,
Ryan
Purple
Ip routing is on by default on the 4500 series and you have to turn it off if you just want layer 2 .
Gregory
259
