Vlan Translations, 6500
Looking to verify if the version IOS on the 6500 will work. This is the document for 12.2SX
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vlans.html#wp1044990
The version running is 12.2(33)SXI2a.   It has the appropriate cards, so just need to verify this version has the commands. I dont have direct access to ty them myself, nor attempt to walk someone through on a production switch.
Thanks in advance.
Green
From the IOS master commands link
http://www.cisco.com/en/US/docs/ios-xml/ios/interface/command/ir-s7.html#wp3252950350
switchport vlan mapping
To map the traffic arriving on the VLAN original-vlan-id to the VLAN translated-vlan-id and the traffic that is internally tagged with the VLAN translated-vlan-id with the VLAN original-vlan-id before leaving the port, use the switchportvlanmapping command in interface configuration mode. To clear the mapping between a pair of VLANs or clear all the mappings that are configured on the switch port, use the no form of this command.
switchport vlan mapping original-vlan-id translated-vlan-id
no switchport vlan mapping { original-vlan-id translated-vlan-id | all }
Syntax Description
original-vlan-id
Original VLAN number; valid values are from 1 to 4094.
translated-vlan-id
Translated VLAN number; valid values are from 1 to 4094.
all
Clears all the mappings that are configured on the switch port.
Command Default
No mappings are configured on any switch port.
Command Modes
Interface configuration
Command History
Release
Modification
12.2(17b)SXA
Support for this command was introduced on the Supervisor Engine 720.
12.2(18)SXE
This command is not supported on GE Layer 2 WAN ports.
12.2(33)SRA
This command was integrated into Cisco IOS Release 12.2(33)SRA.
So 12.2.33SX is supported
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
One last question. Using this configuration on the switchport connected to a router as a trunk port, packets on Vlan 20 will be translated to vlan 3967.
switchport vlan mapping 20 3907
The interface on the router, configured to do L2TPv3 tunneling(which is already tested and confirmed working on 3907), should allow servers on VLAN 20 to work with servers on the same IP subnet on Vlan 3907?
The interface on the router would be configured as
G0/0.3907
encapsulation dot1q 3907
 xconnect 10.100.10.2 3907 pw-class Vlan20
Hi I faced an issue where i
Hi I faced an issue where i van apply the vlan mapping on the physical interface but not on the port channel.With physical interface the vlan transaltion working fine but when i add the physiacl ports into portchannel it fails.Any idea what is missing , appreciate if you guys can answer.
245
