VLANs at 3750 stacked switches
We have 2number of 3750 sw's acting as core(think 1core-DATA, 2core-VOICE) and stacked. There are 5 switches are cascaded to core1 and 1 switch for core2. You consider this is for 1 floor, the same setup is coming from other floor to Core1 & Core2. Can any one suggest, whether we can able to configure VLAN's since 2 cores are stacked.
Naga
1 REPLY
Re: VLANs at 3750 stacked switches
Naga,
You should be able to configure Vlans without any problems. You can configure on one of the switch as VTP server and rest all the switches VTP client. The moment you configure the Vlans on VTP server, they will be propogated to the client switches.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swvtp.htm#wp1288811
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swstack.htm#
HTH,Please rate if it does.
-amit singh
108
