vlans communicating on 1721
TO preface I am still somewhat new to cisco equip and advanced networking. The reason I set the following up is partially to study for my ccna. Anyway here goes.
Business Cable connection coming in to a 1721 running IP plus 12.2. a 2924 xl running ios 12 and two Vlans - one for my server one for my home network. I have both vlans coming from the switch to the router(802.1q), and Nating based on subnet to an external IP. The problem is that A server on Vlan 3(172.16.0.0/24) can ping the fa0(vlan1) ip of 192.168.1.1. It can also ping anoter Vlan ip sub interface 192.168.2.1(fa0.2). When i do a tracert from the server(172.16.0.1) to 192.168.1.1, it shows up as one entry, not even going thru one hop of the gatewate for that VLAN subinterface. fa0/3 on the switch is for vlan 3 and fa0/9 is my trunk port. Here is the config of the switch and the router
switch:
interface FastEthernet0/3
switchport access vlan 3
interface FastEthernet0/9
switchport trunk allowed vlan 1-665,667-1005
switchport mode trunk
and my router:
interface FastEthe
ip address 192.16
ip access-group 1
no ip proxy-arp
speed auto
interface FastEthe
encapsulation dot
ip address 192.16
no ip proxy-arp
ip nat inside
interface FastEthe
encapsulation dot
ip address 172.16
ip access-group 5
ip access-group 1
no ip proxy-arp
ip nat inside
1 ACCEPTED SOLUTION
Re: vlans communicating on 1721
The following configuration would do it, as the NAT order of operation states that the input access-list is processed first, and further both interfaces are inside:
interface FastEthernet0.1
encapsulation dot1Q 1 native
ip access-group 114 in
ip access-group 113 out
ip nat inside
interface FastEthernet0.2
encapsulation dot1Q 2
ip address 172.16.0.1 255.255.255.0
ip access-group 113 in
ip access-group 114 out
no ip proxy-arp
ip nat inside
access-list 113 deny ip 172.16.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 113 permit ip any any
access-list 114 deny ip 192.168.1.0 0.0.0.255 172.16.0.0 0.0.0.255
access-list 114 permit ip any any
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
hi,
Your output is incomplete, please paste it correctly, but i will take one wild guess, the main FastEthernet Interface in the router must have "no ip address".
Mohammed Mahmoud.
w/o an ip address on fa0 doesnt that mean that vlan 1 will not be able to communicate thru it?
No when configuring trunking between a switch and a router, the main interface must have "no ip address", and for VLAN 1 there must be a subinterface like any other VLAN.
Mohammed Mahmoud.
I actually wasnt able to communicate from a pc on one vlan to a pc on another vlan w/o opening it up in an access list. So it seems to be mostly working. I just dont understand why a pc on one vlan can hit all the sub interfaces on the router
here is the complete swtich config
! Last configuration change at 18:26:10 EST Wed May 2 2007
! NVRAM config last updated at 18:26:11 EST Wed May 2 2007
version 12.0
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname Switch2900XL
enable secret xxx
clock timezone EST -5
clock summer-time EST recurring 2 Sun Mar 2:00 2 Sun Nov 2:00
spanning-tree portfast bpduguard
ip subnet-zero
no ip domain-lookup
ip domain-name anarchyunlimited.net
interface FastEthernet0/1
switchport access vlan 100
interface FastEthernet0/2
description ***Faulty***
switchport access vlan 666
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface VLAN1
no ip address
no ip directed-broadcast
no ip route-cache
shutdown
interface VLAN100
ip address 100.x.x.67 255.255.255.192
no ip route-cache
and the router
version 12.2
hostname homeFirewall
enable password password
username user password 0 cisco
ip subnet-zero
ip name-server 192.168.1.10
trunk group 1
trunk group yeah
ip address 192.168.1.2 255.255.255.0
ip access-group 103 in
ip access-group 103 out
no ip proxy-arp
ip nat inside
speed auto
ip address 192.168.2.1 255.255.255.0
no ip proxy-arp
ip nat inside
interface FastEthernet0.3
encapsulation dot1Q 3
ip access-group 5 in
ip access-group 104 out
no ip proxy-arp
ip nat inside
end
is it normal for a pc on one vlan to be able to hit all 3 sub interfaces?
I took out some of the config to save space just natting and login info
Please do check this document:
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a00800949fd.shtml
you must have a separate subinterface for VLAN 1, please follow this document and get back to us if you face any problems.
Mohammed Mahmoud.
Ok. The only reason I thought the other way is because in one of my CCNA study guides(CCNA ICND by Wendel Odem) it states that with dot1q and vlan1 being native you dont set up encapsulation on that vlan.
You are right, thats why we use the "native" keyword with the VLAN1 subinterface encapsulation command as described in the document above but you still need to define dot1q encapsulation on all subinterfaces for all VLANs, please do review the document and come back if you have further questions.
c2600(config-subif)#encapsulation dot1Q 1 native
!-- On the switch, if you have a native VLAN other than VLAN1,
!-- on the router, configure the same VLAN to be the native VLAN,
!-- by using the above command.
Mohammed Mahmoud.
Encap is defined on all sub interfaces. Is it normal to be able to ping the IP on other sub interfaces as thats the main concern I have
Yes currently all the subinterfaces are directly connected interfaces on the same router, and thus packets are automatically routed between them, and thus a host belonging to a VLAN of one subinterface will be able to ping an IP belonging to another subinterface (Inter-VLAN routing - router-on-a-stick).
I hope that i've been informative.
Mohammed Mahmoud.
I applied an access list but the pings from the 172 still hit the 192 sub interface. I applied an access list to the 192 sub interface blocking all traffic from the 172 subnet however the pinjgs still come thru. Is this normal?
here is my access-list set up. I have it fully set up now but the access list to block routing from one Vlan to another isnt kicking in. What do I need to change to be able to control/block intervlan routing
vlan sub configs:
ip access-group 106 in
ip nat inside
no ip proxy-arp
ip nat inside
access-lists:
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 permit 74.93.243.192 0.0.0.7
access-list 3 permit 172.16.0.0 0.0.0.255
access-list 4 deny 172.16.0.0 0.0.0.255
access-list 5 permit 172.16.0.10
access-list 101 permit tcp any any established
access-list 102 deny ip any 192.168.1.0 0.0.0.255
access-list 103 permit ip any any
access-list 103 permit icmp any any
access-list 104 deny ip any 192.168.1.0 0.0.0.255
access-list 104 permit ip any any
access-list 105 deny ip any 192.168.1.0 0.0.0.255 log
access-list 105 deny ip 172.16.0.0 0.0.0.255 192.168.1.0 0.0.0.255 log
access-list 106 deny ip 172.16.0.0 0.0.0.255 any
access-list 106 permit ip any any
I want to block traffic from Vlan2(172.16.0.0/24) to vlan1(192.168.1.0/24)
ip nat inside
no ip proxy-arp
ip nat inside
Mohammed Mahmoud.
THANK YOU!!!!. This fixed it. Only thing I am a little confused on is that i had an accesslist on 0.1 blocking traffic. Does the block have to be on both interfaces to work right? Thanks again for your time on this and it works like it should now =)
I am glade that it worked out :)
The reason it didn't work before is that your ACL was configured wrong:
This shall deny any packet with source "172.16.0.x" incoming to the interface, which will never be the case, as all packets coming inbound to this interface will have source 192.168.1.x, and destination as "172.16.0.x", always take care what is the source and what is the destination when you are configuring an ACL.
Mohammed Mahmoud.
234
