VLANS in Catalyst 2948G-GE-TX switch
Hi all,
how to configure ip address for vlans in cat 2948G-GE-TX switch ?
i need to do inter vlan routing - so i need ip address for vlans.
can i only work using "set" commands ?? any way to make it work like normal 2950 or 3550 switches ?
Please guide me.
Sathish.
Re: VLANS in Catalyst 2948G-GE-TX switch
Hi Satish,
2948G-GE-TX is a complete pure layer 2 switch and is not capable of inter vlan routing. So you can use it for layer 2 functionality only.
For any layer 3 functionality you need switch like 3550 and above.
Ankur
*Pls rate all helpfull post
I think you run an pure "Switch" Image on that machine. I took a look in the Softwarelibrary and found an IOS Image for the 2940:
c2940-i6q4l2-mz.121-22.EA8.bin
Maybe you install this IOS Software on your Switch and then go for the Layer 3 Interface configuration. But pls. install this Software first on a non production Switch and test if it?s working !!!
Rgds,
Andre
Purple
2940 and the 2948 are 2 different animals, a 2940 is a small IOS switch and the 2948 is a 48 port catos box . Both boxes are layer 2 only ....
827
