vlans on 3560 can't talk to each other
ip routing is enabled, there is an ip on each vlan interface, but hosts on one vlan cannot ping hosts on another. All hosts are pingable from the switch.
Hall of Fame Super Bronze
Re: vlans on 3560 can't talk to each other
Did you check the default gateway on the hosts ?
The default gateway on the hosts has to be the Vlan interface IP for each VLAN hosts. If you have correct vlan SVI configured as the gateway it should work.
-amit singh
seems to be strange
R u sure you are seeing the VLAN subnets when you do sh ip route
what code are you running btw?
Narayan
As the above poster said u r gateway of the hosts should be the vlan SVI created on u r swith for the specifed vlan.
Mahmood
Hosts are configured to use the vlan interface ip for their respective vlan as the gateway. I do see the vlan subnets when i run show ip route. Code on this guy is 12.2(25)SEE2 with ipservices.
Can we see the switch config along with ipconfig /all from one of the workstations ? FW enabled on the workstations ?
indc-c3560-1#sho run
Building configuration...
Current configuration : 9888 bytes
! Last configuration change at 10:30:56 PST Thu Jul 12 2007
! NVRAM config last updated at 10:20:26 PST Thu Jul 12 2007
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname indc-c3560-1
logging buffered 50000 debugging
logging monitor warnings
enable secret xxx
no aaa new-model
clock timezone PST -8
clock summer-time PST recurring
vtp domain indc-cluster
vtp mode transparent
ip subnet-zero
no ip source-route
ip routing
ip domain-name synopsys.com
ip name-server 146.x.100.240
ip name-server 146.x.100.241
ip name-server 146.x.100.242
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
name chera
vlan 40
name shared
vlan 70
name management
interface Vlan1
no ip address
interface Vlan10
description Chera cluster
ip address 10.144.205.62 255.255.255.192
interface Vlan20
ip address 10.144.205.126 255.255.255.192
interface Vlan30
ip address 10.144.205.190 255.255.255.192
interface Vlan40
description cluster shared network
ip address 10.144.205.206 255.255.255.240
interface Vlan70
description Management Network
ip address 10.144.205.241 255.255.255.240
router ospf 1
router-id 10.144.205.241
log-adjacency-changes
network 10.144.205.0 0.0.0.63 area 0
network 10.144.205.192 0.0.0.15 area 0
network 10.144.205.240 0.0.0.15 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 10.144.205.254
ip http server
logging history size 500
logging trap notifications
logging 146.225.100.1
logging 146.225.64.9
access-list 2 permit 146.225.64.9
access-list 2 permit 10.15.1.100
access-list 2 permit 10.15.1.101
access-list 2 permit 10.225.1.25
access-list 2 permit 146.225.66.0 0.0.0.255
access-list 2 permit 146.225.100.0 0.0.0.255
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon
snmp-server enable traps mac-notification
snmp-server enable traps bgp
snmp-server enable traps copy-config
snmp-server enable traps config
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-messa
ge
snmp-server enable traps rtr
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistenc
y
snmp-server enable traps syslog
snmp-server enable traps vlan-membership
control-plane
line con 0
login
line vty 0 4
login
line vty 5 15
no login
ntp clock-period 36029152
ntp server 146.x.64.200 version 1
ntp server 146.x.64.240
ntp server 146.x.64.212 version 1
end
indc-c3560-1#
are all the hosts connected to this switch only?
Is this switch trunkie dany other switch?
you have SVI defined for VLAN 10,20,30,40 & 70 but vlans created are only 10,40 & 70
Narayan
hosts are connected to only this switch, and as of now only vlans 10, 40, and 70. No trunking used, switch is isolated by a firewall cluster.
Did you verify the subnet mask matches on the workstation with the corresponding SVI ?
Can we see a 'ipconfig /all' from the workstation ?
Was this working before and suddenly stopped ?
Purple
As narayan said the way it is right now you would only be able to route between vlans 10,40 and 70 as you have no layer 2 defs for the others .
500
