Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
vlans on a catalyst 4506
on this switch, I can see vlans with show vlan command like this:
VLAN Name Status
1 default active
2 VLAN0002 active
80 VLAN0080 active
100 DHCP_Scope_1 active
But in the running-config, I can't see the vlan names. Can anyone tell me where these are defined?
Purple
Re: vlans on a catalyst 4506
Must be running in vtp client mode in which case there is a server feeding this info to the client . It is not in the running config . The only time you will see it in the config is if you are running vtp transparent mode. Do a show vtp status and see what mode it is running in .
Hi Glen,
thanks for the reply. This 4506 has a supervisor engine module, so it should be running in server mode.
Also, in the running-config I can see the vlan interface defined like this:
interface Vlan1
ip address 10.1.1.1 255.255.255.0
interface Vlan2
ip address 10.2.2.1 255.255.255.0
interface Vlan80
ip address 10.10.10.254 255.255.255.0
interface Vlan100
ip address 10.0.0.1 255.255.254.0
But vlan names such as vlan0002, vlan0080 are not there.
regards,
the layer 3 interface does not come automatically.. u need to manually define ip addresses for the vlans, to give layer 3 access for that vlan... just give a show vlan and make sure they are added onto the vlan database. Once it is there in the layer 2 vlan database, u can add the commands, interface vlan 80, ip address x.x.x.x , manually to make layer 3 vlan routing for that vlan... so, i guess whatever u have got in ur switch is right...
Hope this helps.. all the best..
Raj
427
