Community Member
VLANs With DHCP
Dear All,
I am having one doubt, i have one cisco 1841 (12.4) router which is connecting to a cisco 2960 switch, i have 6 Vlans on my switch. Now i want to make my router as a DHCP server, but i want that my router assingn the IP's to Clients on the basis of Vlans i.e. suppose i have 2 vlan
Vlan 1 ---- 192.168.1.0 /24 subnet
Vlan 2 ---- 192.168.2.0 /24 subnet
Now i want my router to assign client in VLAN 1 IPs in range of 192.168.1.0
VLAN 2 IPs in range of 192.168.2.0
Is it possible and if yes can you help me with commands.
Hussain Ratlami
Network Engineer
1 REPLY
Hall of Fame Super Silver
Re: VLANs With DHCP
Hello Hussain,
this is possible and you need to define multiple dhcp pools one for each VLAN.
There is no risk of confusion because the DHCP client sends its request with a broadcast 255.255.255.255 IP destination, the router tracks on what vlan it receives the request and takes an address from the right pool
Config example:
ip dhcp excluded-address 10.110.224.129 10.110.224.132
ip dhcp excluded-address 10.110.224.145
ip dhcp pool DATA
network 10.110.224.128 255.255.255.240
default-router 10.110.224.129
dns-server 10.98.112.32 10.55.0.32
netbios-name-server 10.52.64.37 10.24.128.151
lease 0 1
ip dhcp pool VOICE
network 10.110.224.144 255.255.255.248
default-router 10.110.224.145
option 150 ip 10.98.67.5 10.55.61.4
lease 0 1
in your case just adapt to 192.168.1.0 and to 192.168.2.0 using mask 255.255.255.0
Hope to help
Giuseppe
119
