VMWare ESX and portfast
Is there any downside at all to enabling portfast on an ESX server? Do I have to worry about vSwitch creating loops or any other reason that would cause a loop doing this? It is a end host after all.
John
HTH, John *** Please rate all useful posts ***
1 ACCEPTED SOLUTION
Re: VMWare ESX and portfast
i dont think so. as far i as know you need to enable portfast on the interface to prevent any connectivity issue. you dont want your ESX server taking part in spanning-tree transtion process so with portfast the port the ESX server is connecting to will transtion to forwarding state.
good doc http://www.cisco.com/univercd/cc/td/doc/solution/vmware.pdf
1 REPLY
1279
