10-31-2006 03:06 PM - edited 03-05-2019 12:33 PM
Hi:
just wanna ask a an example of complete voice vlan config for the Cisco-3750 and Cisco-3560 switches.
Does Voice VLAN also requires and IP just like Access VLAN?
Example:
int vlan 10
ip address 10.220.10.254 255.255.255.0
Cliff
10-31-2006 03:19 PM
Hi Cliff ,
Complete config for voice vlan for 3560 link is below.
Complete config for voice vlan for 3750 link is below.
Hope this helps you a lot.
satish
11-02-2006 05:25 AM
Hi:
I can't access the link. its asking for CCO account.But ill just ask one question,if access vlan interfaces needs ip address inorder for the hosts to have it as a gateway, does the voice vlan also must have?
thanks
11-02-2006 05:38 AM
Hi ,
Voice VLAN is only supported on access ports and not on trunk ports, even though the configuration is allowed.
The sample config of voice vlan config is
Switch# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# mls qos trust cos
Switch(config-if)# switchport voice vlan dot1p
Switch(config-if)# end
In which Valn id is Valid VLAN IDs are from 1 to 4094.vlan-id?Configure the Cisco IP Phone to forward all voice traffic through the specified VLAN.
You should configure Valn so that all voice traffic is passed through that vlan.
Satish
