Voice VLAN-Portfast & PortSecurity
If we need to connect Cisco IP phone and the a PC connected to this IP Phone, with Voice VLAN as 10, and Workstation VLAN as 20.
Here is the configuration:
int fa1/1
switchport access vlan 20 ( workstation )
switchport mode dyna desir
switchport voice vlan 10 ( voice VLAN )
msl qos trust cos
msl qos trust device cisco-phone
spanning-tree portfast
If we configure like this, will the interface act as a trunk - so that it will for a trunk with cisco-ip phone and will send and receive tagged frames to cisco-ip-phone and will send untagged frames to workstation connected next to IP phone. ( native VLAN ).
What is the effect of portfast command ?
Or this is an invalid configuration?
Is is possible to apply port security for these interfaces. ( like max-mac, or sticky , voilation)?
Please share the experience.
Any link on cisco.com?
Thanks in advance.
Subodh
Re: Voice VLAN-Portfast & PortSecurity
Hi Subodh,
Here are some Voice VLAN configuration guidelines:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2970/software/release/12.1_19_ea1/configuration/guide/swvoip.html#wp1002608
The configuration you posted looks good, except that the switchport mode should be set to access, since the port should not negotiate to become a trunk.
spanning-tree portfast will instantly put this port in forwarding mode without waiting for the spanning-tree timers to expire, which is recommended for an access port. Portfast should not be configured on trunk ports however.
The interface configured like this will tell the phone via CDP to send its frames tagged with VLAN 10. The PC will send untagged frames, and these will be put into VLAN 20. With some none-cdp speaking phones it might be necessary to configure a trunk manually.
Check the above link for port-security guidelines.
hth
Ingo
Hi Ingo,
Thanks for you reply that document listed in the link is great and has clarified most of my doubts. But still there is one spike of doubt that is I am not clear about and that is about "access port". If we configure the port to be access port how can it carry tagged frames whcich are destined for cisco IP phone and un-tagged frames for a workstation. Does this form any kind of special port that is not a trunk but can still carry tagged frames and untagged frames. I am not able to understand if someone can help it's really appreciable.
Thanks in advance
Subodh
due to this reason we care calling voice vlan as "Aux VLAN" or else there should not be any separate config such as voice VLAN and could be left to the phone to tagg and work over a trunk.
In voice vlan the action is not on full fledged trunking but a kind of agreemnet for 2 vlan and not more than that...
518
