Voice VLAN
I wanna clarify few things on the voice vlan;
1) I am going to use 1000+ phones on my new work and my current configuration is;
interface GigabitEthernet0/1
description PHONE D104
switchport trunk native vlan 4
switchport mode trunk
speed 100
duplex full.
The native VLAN is for the PC. But is it a good configuration. Now i am planning to put voice vlan.
Which configuration will be good, trunk or voice.
Re: Voice VLAN
i think it will be good to define seprate vlans for both data and voice.And in u r above config u havent defined the voice vlan.
intergace gig/0/1
switchport mode access
switchport access vlan 4
switchport voice vlan 10
spanning-tree portfast
Mahmood
Re: Voice VLAN
Thanks mahmood,
My current setup is not having a voice VLAN as it is configuring on the phone. (specifying the vlan on phone).
But now i am planning to put the voice vlan, does a mls qos is necessary for IP phones.
Re: Voice VLAN
Hi Drnteam,
You should definately use Voice vlan's. If you don't you will most likely have voice quality issue's.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_se/configuration/guide/swvoip.html
Just add this to your config on your interfaces if you are using Cisco IP Phones.
Make note of the prompt #.
Config#mls qos
interface FastEthernet1/0/4
description IP Phone/Data Port
switchport access vlan xx
switchport voice vlan xx
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree bpduguard enable
HTH, Please rate
Justin Brenton
258
