VOIP phone not getting IP from correct VLAN
Andy White
Level 3
Level 3
(sorry not sure if it is a VOIP or Switch issue)
We are installing a couple of VOIP phones in a new office, the VOIP service is hosted and the phones are Yealink. Off these VOIP phones are PC, but both the phone and PC get an IP from the DATA VLAN, I want the VOIP phone to go on it's VOICE VLAN.
Here is an example of the port, it is a Layer 2 switch (2960x):
description PC & IP Phone
switchport trunk native vlan 10
switchport trunk allowed vlan 10,62
switchport mode trunk
spanning-tree portfast trunk
spanning-tree bpduguard enable
The trunk port:
interface GigabitEthernet1/0/24
description ROUTER-LAN
switchport trunk allowed vlan 1,10,62
speed 100
duplex full
Router:
ip dhcp pool Data
   domain-name gb.vo.local
   default-router 172.30.12.8
   dns-server 192.168.21.10 192.168.21.11
   option 66 ip 192.168.28.89
ip dhcp pool Voice
   network 172.30.212.0 255.255.255.0
   default-router 172.30.212.1
interface FastEthernet0/1
description LAN
no ip address
duplex full
speed 100
interface FastEthernet0/1.10
description DATA LAN
encapsulation dot1Q 10
ip address 172.30.12.11 255.255.255.0
standby 1 ip 172.30.12.8
standby 1 priority 110
standby 1 preempt
standby 1 track 1 decrement 10
interface FastEthernet0/1.62
description VOICE VLAN
encapsulation dot1Q 62
ip address 172.30.212.1 255.255.255.0
Does it all look ok?
I can see the phones:
sh lldp neighbors
Capability codes:
    (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
    (W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID           Local Intf     Hold-time  Capability      Port ID
IPPHONE             Gi1/0/14       138        B,T             0015.654c.6630
IPPHONE             Gi1/0/19       156        B,T             0015.654c.65f6
10 Replies 10
Guru Mysoruu
Hi Andy,
Is the configs are you posted is correct.
Then,switch configuration must be
switchport access vlan 10
switchport voice vlan 62
Your Voive pool Must be
ip dhcp pool Voice
   ip helper address ( Your DHCP address)
   option 66 ip TFTP Address
your default router of vlan will be vlan address itself
For your data network,you dont need option 66
I will try your config.  The DHCP I think is correct as they download the config via the internet and if I make the port just vlan 10 it works
Karthick Murugan
Hi Andy,
In the DHCP pool of voice and data, please specify option 150.
option 150 ip
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Hi Andy,
Please look at the below post as well which would help.
https://supportforums.cisco.com/thread/2146496
Thanks & Regards,
Karthick Murugan
CCIE#39285
John Blakley
If you're wanting to use lldp for the phones, you can create a network profile and then apply that profile to the individual ports:
network-policy profile 1
voice vlan 10
interface FastEthernet0/3
switchport mode access
network-policy 1
mls qos trust dscp
The phone will see lldp from the switch and place itself in vlan 10 (change to what you're needing). You then don't need to worry about putting your phones on a trunked port. I don't configure my ports like the above on most of my switches though. For the most part, the phones connect to the PC which connects to the port on the switch. The switchport is trunked for both vlans - data and voice. The phone gets an address from the native vlan which also has the string that tells the phone what vlan it should be on. The phone then changes to that vlan and pulls an address from the voice vlan along with any information that it needs for the call server etc.
Looking at your config, I'm not sure what string your phone supports, but somehow you have to tell it what vlan to tag its traffic with. As Karthick mentions, option 150 is one type of string, and there is option 242. You have to find out which one your phones support and use that to tell the phone what vlan to tag their traffic with, set the call server to, etc.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Seems:
Fixed it, I will know more in the morning, but our VOIP portal with Natterbox who host this VOIP services sees it all as good and has sent the config and firmware down to it successfully, plus I can ping it.
Will know more in the morning.
Seems I spoke too soon.
The VOIP phone works but the PC connected via te VOIP phones gig port can't get a DHCP address, an ideas?
Hi Andy,
The problem is,there is mismatch in data vlan and voice vlan dhcp pool.
remove option 66 for ip dhcp  data pool in your config
enable option for 66 for voice vlan
Retain same switch config
Now both will work
Andy,
Your DHCP pool for voice and data don't make any sense.
Post the configuration which contains the DHCP pools, exceptions and the VLAN IP addressing.
All was all good, it was jus tthe network command missing:
ip dhcp pool Data
  network 172.30.12.0 255.255.255.0
ip dhcp pool Voice
