VPN behind NAT
I am in the situation where i can not have more than 1 public IP address in one of my branch offices, and the possible soution with available hardware is going to be look like this,
INTERNAL SWITCH(OFFICE LAN) 10.250.1.0/24
CISCO ASA 5510 (NAT/PAT/VPN)
CISCO 1841
-------INTERNET--------
Cisco 837(NAT)public IP address
Watchgaurd X15 (VPN/NAT)
WAN PORT: 192.168.0.254
INTERNAL: 10.250.2.254
INTERNAL SWITCH(Office LAN 10.250.2.0/24)
A SITE TO SITE VPN tunnel needs to be establish between CISCO ASA in HEADOFFICE and WATCHGAURD in BRANCHOFFICE, Can anyone have a look to see if this will work without any problems, primarily the branch office will run CITRIX sessions over the VPN.
Re: VPN behind NAT
(Configure public ip on interface connected to 1841 router and do NAT over here)
CISCO 1841
(Configure another IP address on same segment on interface connected to ASA. Give defaut route to serial interface)
If you do in the above way, I think it should work.
Please rate the posts if helpfull.
Suresh Jain
Re: VPN behind NAT
Its exactly what i intend to do, I am only nervous about the cisco837/Watchgaurd Side of the network where NAT over NAT situation is.
Muhammad
Re: VPN behind NAT
All we need todo is Configure Nat in the Firewall and Configure the Routers Serial Interface as unnumbered to Eth.
Totall atlease 2 Pub Add is needed.
Danny
Re: VPN behind NAT
any comments on running NAT over NAT in branch office side of network, i have no proglem in headoffice, have enough resources.
thanks
Muhammad
Re: VPN behind NAT
You can do NAT over NAT without any problem, but be carefull while configuring.
Rate the post if helpfull,
Suresh Jain
282
