Bronze
VPN routes
I need to clear concept reg VPN routes.when we config and initiate a vpn the basis is considered to be the peer and the access list.
once the vpn is thru ,if we check the route table.there is only route related to the peer ip and no route for vpn apart frm tht.how is tht ? or is it tht once vpn tunnel is thru, it acts as directly connected at both ends and thus doesnt appear as specific routes
Please clarify.
Thnks.
Hall of Fame Super Blue
Re: VPN routes
Are you talking about client VPN's here. If so only one route is needed (unless you are doing split tunneling). The route says to get to any network go down the VPN tunnel to the peer IP which is exacty what you want. So you don't need individual routes for each remote network because the path to all remote networks is down the VPN tunnel.
Hope this makes sense
Jon
Bronze
Re: VPN routes
Hii,
am talking about ipsec tunnel.if i do a ip route shud it show me the other network routes giving any indication tht its thru with a tunnel?
Thanks for your reply.
104
