vrf-lite on lan
on our lan we want to use vrf-lite to isolate 2 vlan from the others but they have to interact with the vrf WAN for exemple so there might be route leaking
Just a question about the conf
what's the difference between this config
ip vrf wan
rd 1:1
route-target export 1:1
route-target import 1:1
is it mandatory to apply these 2 route target ???
can we make this?
ip vrf wan
rd 1:1
export map wan-map
so we just export we want to for the vrf wan
What is the best solution
Re: vrf-lite on lan
route-target configs are only required if you run MPLS. Since you only want to run VRF-Lite, you don't have to configure route-target for your VRF(s). Consequently, there's not export-map required either. If you start playing around with export-map and the likes, you're opening up a whole new can of worms, 'cuz then you need to set up MP-BGP, etc. Unless you do want to set up your own MPLS network.
I don't think you need to create a "WAN VRF". You only need the 2 VRFs and the global routing table. How many layer-3 devices do you have? If you only have the WAN router as the routing device, you may not even need to leak routes. Just relevant static VRF routes in each VRF to reach the WAN (default route may be sufficient?). Might help if you can provide your intended network topology.
Re: vrf-lite on lan
hi,
"You only need the 2 VRFs and the global routing table."
How can I make this?
a static route in the 2 VRF to reach the WAN who
is in global table?
thanx
Re: vrf-lite on lan
well, what I meant was that you don't need "ip vrf" config for your "WAN segment". Here's an example config:
ip vrf Segment1
rd :1
ip vrf Segment2
rd :2
interface
description SVI for Segment1
ip vrf forwarding Segment1
ip address
interface
description SVI for Segment2
ip vrf forwarding Segment2
ip address
interface serial0/0
description WAN
ip address
Note on RD: best practice typically calls for BGP AS number being used for the 1st part of RD, while the 2nd part is typically an arbitrary number that you choose.
Now, not knowing your exact requirements or your topology, I can't guarantee that the configs above will meet your needs. They're just a guide. Will help heaps if you can provide topology and also state your requirements.
283
